VC2005 MFC menu bar add event handler problem
26 Jan 2005
Cheltenham, UK
Hi guys,
Okay so I've been stuck on this for over a day now. I've tried doing lots of googling and browsing MSDN etc.
I'm editing an existing c++ application. The app itself is working fine.
I'm trying to add a new about window popup (you know help, about etc). The app GUI is defined in the *.rc file.
I've added the file menu and created the pop up, however I don't seem to be able to link the two. I'm pretty certain I need to create new *.cpp and *.h files for the about box and link them in using the 'add event handler' however I'm not sure how to do it exactly.
I hope my problem is clear and apologies for such a noobish question.
Any help would be much appreciated :)
