Ahh I am getting it now!
Just two things that confused me there, you said:
Wouldn't that mean the "lower" the ram divider? Cos if I pushed my FSB up higher, I would have to lower the divider from 400 to 333... right? Or is that what you meant?
Finally, I had to ask this, cos you used the word knacker, and I don;t want to blow any parts up if possible
You said:
People use the word HTT aswell as FSB... and you say keep it below 1000... 1000 what? Obviously not mhz, cos its way above that already? So I assume you mean something else... where can I cehck what it is at? i.e. Is there anywhere in the BIOS that will tell me if its over 1000?
Sorry, as you can tell I really doon't know too much.
Thanks again! Your helping me out alt here!
Defcon5 said:The higher your HTT, the bigger the ram divider
Defcon5 said:HTT bus will knacker at above 1000 (stock 200x5) so use whichever multi you need to keep it below 1000
