- 11 Sep 2008
- Co. Durham
Ok here goes as im getting confused. If a max vcore for a given chip is say 1.35 from intel and these 3 ways to measure the vcore core
1. in bios
2. windows idle (cpuz)
3. prime load (cpuz)
which one are we supposed to be reading from to stay with limits? Does it matter if your windows idle is above the limit as long as load vcore is under?
same for the bios can you put say 1.45 in the bios as long as load vcore stay at 1.35?
1. in bios
The margin of error is certainly lesser than that read by CPU-Z (albeit the latter was found to be fairly accurate). What you set in BIOS isn't an actual output but what your board should aim to do.
