I have recently put an E8300 CPU in my GA-N680SLI-DQ6 motherboard. On the gigabyte site it says the E8300 isn't supported but it seems to work fine. The PC boots and runs great. However I noticed that the CPU was running at 2.6 instead of the 2.8 standard so I went into the bios to have a look and noticed that it says Vcore fail in the status. What does this mean? I assume its because the CPU isn't supported? Will it create problems if I continue to run the PC with that error? I do have options in the bios to increase voltages and the FSB would increasing the voltage help?
