Hi guys
I know this sounds a dumb question and probably is.
Is there a way to lower vcore without lowering vcore itself by using another setting ?
The reason i ask is that i have hit a speed that is using 1.4 vcore and i know the highest recommended is 1.38 so i want to bring this down a bit to the 1.38 mark but not by lowering the vcore itself. Im using the offset mode on the Asus P8P67 Pro with an offset of + 0.030
Many thanks.
Many thanks.
. I do have speed step enabled so it will drop down when i stop prime95.
