hi,
Ive recently fixed up my previously hot system by adding a corsair h50..loverly bit of kit i must say, anyway with the new cooling I was hopeing to finaly realise the potential of my q6600, so armed with enough guides to baffle a jedi i went about setting up the system to run faster...
everything went fine until i tried to push the cpu past 2500 ... yes ..2.5..
is anything running hot? no
but to my amazement when in windows using ntune i can bump the speed up to 2.7 ish being stable.
My first though was settings but after going through everything i can i put it down to vcore as it will just hitting 1.2v at the 2.7..
so in bios i go to the overvoltage section and bump it up to 1.25
does it do 1.25? .. .no .. it goes whatever voltage it wants to go at..
so this is a plea for help, if its a setting then ill look stupid but at least i will get the system up to speed, if its 1 rubbish component.. well.. i guess its time to save up again.. but any help advice or questions are more than welcome.
heres the specs:
Asus p5n32e-sli
corsair dominator 1066 stuff (5 5 5 15 @ 2.100v)
Q6600 g0 stepping
8800gts 320mb
Xfi-Xtreme gamer
550w generic psu
Corsair H50 cpu cooler
I cant think what else to put down that might effect the system.. still if you can think of anything do ask.
Im trying to get the system to 3ghz .. or at least 2.8 surely the "legendary" q6600 could handle this? unless i have the only special robin reliant edition cpu..
anyway, thanks in advance for any help.
heres the specs:
Asus p5n32e-sli
Q6600 g0 stepping
8800gts 320mb
Xfi-Xtreme gamer
550w generic psu
