vcore on e4300 overclock
8 Jan 2007
hi all,
i've overclocked my e4300 to 2.7Ghz and according to CPU-Z its running at 1.264V and thats pretty stable.
was just wondering, even though i know intel say the max is 1.35 and i'm not even running at that (the bios vcore is set to stock which is 1.325000) and overvoltage is 0.1V, i saw the e4300 overlocking thread at that over clock which was like 3.3ghz and that was only running at 1.213V. so that got me a little worried.
is my voltage too high?
thanks mate,
system temp seems to be about 30 degrees and cpu temp around 40ish at orthos load on small fft priority 4.
cpu idle is around 30 degrees with the cpu cooler on low (Titan Vanessa)
almost 1ghz overclock on 1.264 vcore...that's very impressive. :)
I'd pump it with some more vcore and go for 3+ghz
christ, im on 1.42 and im only overclocked to 2250!!!
Think i better reduce it a bit!!! then try to overclock some more :D
