- 16 Jun 2008
Hi Folks,
Trying to get my system stable at 3420Mhz, am getting Fatal Errors in Prime usually after a few hours. Im sure its voltage related and have been increasing notch by notch until stable.
Trouble is this, in speed fan when i set the BIOS CPU Core at 1.4525v i get the following readings under full load:
VCORE 1.52v (in SpeedFan settings, it says the chip is "Winbond W83627DHG")
CPU Core 1.37 (chip "uGuruP35-Pro) which i believe is correct accounting for vDrop
These then drop to the following at idle:
VCORE 1.5v
CPU Core 1.34v
But im concerned with the VCORE above 1.5v as i know its not wise to increase the voltage above this. Also, theres no sign of vDroop at all, unless ive got my ideas wrong as i thought its supposed to decrease the volts under load.
Anyway, can anyone clear this up for me? Im very confused, and whilst ive been told to believe the CPU Core voltage (which is the same in CPU-Z) by one member on here, I really dont like seeing the VCORE voltage of 1.52v! So would like some confirmation as to which of these voltages is correct, whether i should be concerned with the VCORE reading and what its actually refering to?
Many thanks in advance!
VCORE 1.5v
CPU Core 1.34v
