- 4 Feb 2006
- nottingham
I have the Spec in the sig below running aN832 sli.
At present I have not had the system long and still getting familiar with the setup after prevoiusly owning a barton. Accoriding to the bios and PC Probe my Vcore reports at 1.44Volts, I noticed a lot of peoples posts reported it to be lower 1.4 or 1.35 according to other sources I have seen.
I am sure this is right, I have not adjusted any of the settings in the jumperless config in the bios, no AI overclocking is enabled, as firstly I thought it may be that.
I am probably worring about nothing just want someone to confirm this is ok?
than mine on the AUTO setting it reads it around 1.46 on ASUS probe. ALthough he is using an older bios.
