Firstly, Coretemp shows the VID of my chip at 1.3125, from what I can gather this means this is the nominal voltage the chip should run at - not quite as low as others are getting but hey ho.
Now in the BIOS the stock CPU voltage is also 1.3125 but I've raised this to 1.3725.
In Speedfan when under load the VCore is shown as 1.31 and when idling it drops to 1.13 - CPU-Z also shows the same. My first question is whether the voltage is dropped when Speedstep is active - if so then I never realised it did this - if not then why is the voltage dropping? Second question is whether the 1.31 load reading is accurate as it's quite a bit different from the 1.37 I've set in the BIOS - what to believe?
