VDSL INP and Interleave info explanation?
19 Apr 2012
Would someone be as kind to explain interleaving depths and also INP for me?
I fibre connection initially synced at 75Mb but after trying home plugs my sync went down to 48Mb in two days. They were removed and sent back. Within a few weeks, My sync had recovered to 64Mb and Zen confirmed a cap was still on the line. They suggested waiting a few more weeks. Today however, My ECI modem re-synced at 60.1Mb and pings increased to 40ms approx. I took the opportunity to connect my unlocked HG612 and made a slight adjustment to my internal wiring.
What do the different levels of INP mean? What do the numbers correspond to for the interleave depth?
These are the stats I pulled from the modem earlier using DSLstats.
Line attenuation (dB): 0.0 0.0
Signal attenuation (dB): Not monitored
Connection speed (kbps): 64986 19998
SNR margin (dB): 6.1 7.0
Power (dBm): 13.6 7.4
Interleave depth: 1363 607
INP: 3.00 4.00
G.INP: Not enabled
