vDSL router for bt infinity with custom firmware?
31 Dec 2003
Stoke on Trent
Hi all
My hh5 has gone bad and I've always fancied a router which can be flashed with one of the open source firmwares. (I remember that days of ddwrt and tomato but unsure if they're still modern)
Any ideas on what to get? Would prefer a router/modem in one box but its not a show stopper.
Cheers.
For the most part the open source firmware isn't available for routers with internal modems.
If you want to use a router with an Ethernet WAN then you'll need to get hold of a separate VDSL modem. Best bet is a second-hand Openreach HG612.
Hi all
Cheers.
What do you mean by the HH5 has gone bad? Type A/B?
Assume I'm ok with getting a modem from auction, which cheapish router would you suggest then for custom firmware?
It's got a constantly flashing green light and won't factory reset. Can't tell its chipset / type, is there a way I can tell without opening it up?
I know some people have had issues with the Type A's. You should be able to look at the bottom of the Homehub, where the two feet are and it will tell you there.
I have the Type A but if you are having issues it could be worth speaking to BT and mentioning the newer version (Type B) and if you could have that as a replacement?
Cheers.
You can flash Asus Routers with custom firmware. You can also flash the DSL-AC68U it's not officially supported though which turns it into a RT-AC68U.
Like merlin https://asuswrt.lostrealm.ca/
For BT, I have and would recommend getting the Huawei HG612 or ECI modem (depending on your local cab), which is the official one BT used to provide, with a decent router.
It gained me a good 5-10Mbps, decent WiFi and reliability.
Is there a particular feature you need from a custom flash or do you just want to play?
If you want features, a £35 Routerboard gives you pretty much everything.
Just a play. I'll look into that, thanks, sounds interesting!
Cheers, what router do you use after the modem?
Thanks will google that one
If you just want to play around with something that has billions of options then get an Ethernet modem like an Openreach Huawei or a DrayTek Vigor 130 and plug it into an Ubiquiti EdgeRouter.
