VDSL2 bands - Higher bands / frequencies cause TCP packet retransmission
30 Jun 2019
I've been experimenting with disabling different VDSL2 frequency bands , such as D1, D2 and D3 (tested via an ethernet LAN cable). What I've found is, completely disabling the D2 and D3 bands reduces TCP packet retransmission to 0%, as shown below:
However, with the default D1, D2 and D3 bands enabled, I get around 2% retransmission:
There is also some packet retransmission with the D1 and D2 bands enabled:
these results were tested with the SNR margin set to 2dB on my VDSL modem / router (to increase downstream sync speed).
Also, this was the website I ran the tests on:
https://speed.measurementlab.net/#/
So, I suppose what I wonder is, how much does packet retransmission (or loss) matter for every day use, and for specific uses like voice calls and online game streaming?
So slightly higher latency and half the bandwidth. Looks like a win to me.
I suppose it shows that the higher frequency VDSL2 bands can be a bit unreliable on longer lines like mine (I don't have a shorter FTTC line to test on).
Using the D1 band only is a way to make a VDSL2 connection more reliable, by restricting the downstream frequency range to ~0-4mhz (since the higher frequencies have a lower SNR).
Also, the download rate seems very steady with only the D1 band in use. With all downstream bands active, the download rate can dip 10-20mbps sometimes.
I've be interested to know if anyone else has had similar experiences with VDSL2 / FTTC and if so, did you find any ways to mitigate the packet retransmission / packet loss?
FTTP should solve any problems with packet loss/ retransmission, but for many, this upgrade is years away...
