Vector and photoshop
28 Sep 2003
London
Hi know that illustrator is better for creating vector graphics
but how do you know when you make something in photoshop if it is vector or not.. ?
if i type some text and put a box around it, how would i know if that is vector or not
thanks..
Or text.
Just output as a Photoshop EPS/PDF. Should keep it vector if you don't use faux bold or italic. Ofcourse don't rasterise the text :p
Photoshop isn't a vector program, nothing you do in it will really be a vector, the background colour etc. will be raster based. You need to use Illustrator or a similar vector based program and then, when you save the piece out you need to make sure its saved in a vector file format such as a .eps.
