Vectra temp gauge not moving much...
25 Nov 2006
Ipswich, Suffolk
Hi,
Took my new Vectra on it's first long run at the weekend since I've owned it. First of all, it was great (compared to my old Corolla!). So much more comfortable and effortless cruising on the motorway. 70mph and wasn't even do 3000rpm.
Anyway, I noticed the temp gauge didn't move until I slowed for traffic or a junction/roundabout. Then it would climb to 90, and once I was moving again it dropped back down.
Output from the heater seemed fine and mpg was 38 mpg over the 200 mile trip with a bit of stop/start and the start and end of the journey.
If it helps it's a Vectra C facelift, 57 plate 1.8i vvt (petrol)
Sure it will have a warranty being a 57 plate? If it's an aftermarket warranty, they're usually extremely fussy on what they cover and what they don't, so make sure you are.
My '55 Vectra 1.8i did exactly the same thing.
One 20 quid thermostat later it was fine, its very easy to change, right on the front of the engine (if the warranty is no good). You'll find the heater much stronger too as a bonus.
