Hi,
Just received my VEGA 64 Sapphire Limited Edition card on Friday.
Amazing card and performance so far. Yesterday when I installed it and the drivers I ran 3D Mark Fire Strike but the system froze and the screen went black. Preceded to press reset on my motherboard and it restarted to windows just to lock up/freeze doing the same thing. I left it be and assumed that a driver was buggy etc. Fast forward to today woke up went to play some Destiny 2 and while playing the system hang I heard the windows hardware sound, as if a usb drive had been unplugged and I reset the system to try fix it. System went off and on but there was nothing on my screen said display port signal not detected. So I cleared my CMOS, changed my PSU, changed my PCIE slot on my motherboard, changed psu cable to another extra cable in the box, reseated and tested my RAM, booted with 1 stick of ram, but none of these things worked and was still receiving no input on monitor. I then switched to my Integrated Graphics on my 7700k and got into windows to find that Device Manager no longer detects that my GPU is plugged in and that AMD Radeon Settings no longer detects hardware.
Now my biggest issue is that the Sapphire Limited Edition uses the same pcb/shroud as every other limited edition card but the RADEON LED logo and the R cube in the bottom right hand corner are still lighting up.
But the GPU Tachometer above the PCIE connector isn't showing activity and that the GPU's fan isn't spinning what so ever.
Is my GPU Dead? As I have never done so much steps with no joy and the fact the fan isn't spinning and it isn't being detected leads me to believe so.
Thanks
Thanks
