Vega 64 help before purchase
10 Nov 2017
Hi everyone,
I'm debating the Red DevilVega 64 but I'm unsure about clearance. It's a tri- slot cooler and would leave about 1cm to 1.5 cm of clearance between the fans as the PSU shroud of the meshify c mini.
In have good air flow in the case with 2 120mm noctua fans in the front.
Will that be enough clearance or should I look to a smaller cooler?
Thanks in advance for all the advice.
