Look through this: https://www.overclockersclub.com/reviews/vega_efficiency/
What V56 do you have? What's your case/fan situation? How hot does it get exactly? Where is the PC located, etc. We need more info.
Radeon V56 Sapphire.
Seems that I got it. My system uses now about 300..310W (95W i7 2600K, 30W 27'', 180W Amd Vega56). The thing is that this stock cooling system is not good enough...
Which Sapphire card is it? The reference blower or the Pulse?
It is the reference blower. Now it is totally OK, (about 260W in my game with the same game configuration as it was before with RX580, maybe i will install the old card to check the power consume also).
With a custom cooler system the Vega 56 can be really cold and quiet (I will try this one:Raijintek Morpheus II).
Alright guys, i am sure this is all gonna get repetitive, specially for OP, but honestly sometimes too much info and content actually hinders the effectiveness...I just got an MSI Vega 64 Airboost OC for round $375...Now i am trying to figure the best settings and as OP mentioned on his first post i rather have a stable/cool/efficient card instead of all the craziness and heat stuff...So I am trying to follow OP below line:
Quote "...On stock reference Vega 64, drop mV to 900 for all voltage settings and set PL to 50%. You will get a better performing GPU that does not throttle, has a very noticeable reduction in power consumption, noise and thermals. 30% reduction in power consumption makes Vega 64 a very efficient GPU...."
OP When you say "Set Power Limit to 50%" you mean to bring it down form 100% to 50%..since every single person ive seen suggests to actually push it to 150%...or an exra 50%...I apologize for my ridicule noobiness....
And thank you for your help.....
from now and then i get this stutter on the sound and image not sure whats going on like if gets stuck....
Thank you GUys in advance.
Could probably be....i have been running Anthem in ultra (granted i have a very crappy monitor) but the card is holding itself .....the screenshot shown i believe is the best settings i have found so far....Happens to me too recently, think it might be a case of not enough voltage. It's just that it happens so rarely it's hard to say for sure.
