if I was to upgrade my gpu, but went back to AMD, would the vega 56 be the one to look at?
What's your budget?
I don’t have one and likely go 2nd hand if I bother as well, for example I saw a vega 64 for under £230 on FB the other day, seemed a good price I guess?
But I’m just wondering where the upgrade path starts right now
I would be wary of buying a Vega without warranty.
You'd need to upgrade your 2200g aswell.
Apologies 1200, i got you mixed up.
Think about the fact that your sig says you only have a 450w PSU as well.
AMD make some good cards and are well priced, but they do use more power than the NVidia counterparts, so be wary of that.
I wouldn't want to risk a Vega with a 450watt PSU. Therefore you'd want to look at a 5700 which consumes less power unless you're also upgrading the PSU.
