Vega64 Help
30 Jun 2014
S-O-T
im having issues getting games to play "smooth" all seem to be playing jerky
doom
castlevania lord of shadow
injustice 2
What I mean by jerky when you pan left to right and vice versa or action goes fast the picture jerks
Using MSI afterburner my cpu usage is only 25-30% on them so its not a cpu issue it seems
ive also switched to optimised which did fix the slow down in pes 2018 but due to new drivers pes2018 will no longer load without bluescreening my pc
In afterburner or the radeon drivers what temps are being reported when playing. Anything north of 80C will get thermal throttling. Is your case well vented as these cards can generate a fair amount of heat.
doom
injustice 2
a) Did you use DDU in Windows safe mode to wipe all GPU drivers for Intel, AMD & Nvidia? After clean up, did you use CCLeaner to fix registry? (before installing any drivers). Did you made sure refresh rate of monitor is correctly set by windows?
b) Do you use 18.12.3?
c) Remove completely MSI AB as is not needed. Use the AMD overlay if you want to observe performance and has much superior tools to tweak the card.
d) If issues persist you need to create (if not exist) game profiles. Go to Wattman settings, and select minimum speed the P7 state. Launch the games from the Wattman.
eeii temps have not gone above 75
panos
a) ddu yes and ccleaner my monitor is a dell dg2716dg monitor ive set it to 144hz in windows
b yes just installed doesn't seemed to have made any difference at all
c) will do
d) ill look ghow I do that as I don't know how to
doom
injustice 2
panos
c) will do
Considering your monitor is 2560x1440 res 144Hz, it doesn't seem right the CPU usage would be so low, considering pushing 144Hz require lots of CPU grunt.
What kind of settings are you using in the games you mentioned? Nothing crazy like 8xAA etc I hope?
I'm not sure of settings I'll have to check but castlevania only let's you change resolution nothing else unless i missed them
Castlevania Lord of Shadow is an old game from 2010, so considering the year that it came out, it is likely that the game engine would may only be using 1-2 threads/CPU cores.
I don't think graphic wise Vega64 would struggle with this game at all, but I am betting that it is the CPU bottlenecking (because of the way the game engine is) the Vega64, and it is what stopping you from getting a solid 100fps+ for the 144Hz monitor.
My cpu is 8700k
I've looked at some old reviews, and it would seem that this game is not particularly CPU demanding and it would generally be GPU bounded:
https://www.dsogaming.com/pc-perfor...ania-lords-of-shadow-pc-performance-analysis/
"As always, we used an overclocked Q9650 (4Ghz) with 4GB RAM, an Nvidia GTX690, the latest version of the GeForce ForceWare drivers and Windows 7-64bit. Nvidia has already included an SLI profile for this title, so you won’t have to mess around with third party tools in order to enable it. SLI scaling is great, and the game ran with constant 120fps at 1080p. Even though Castlevania: Lords of Shadow is a GPU bound title, a GTX 690 is more than enough. Our graphics card was able to pull some incredible numbers when we disabled VSync at 3200×1800. Naturally, we wanted to see how a single GTX680 would perform, therefore we also ran it under Single GPU mode. And to our surprise, a GTX680 was able to run this game at 3200×1800 with constant 60fps and at 1920×1080 with constant 120fps (max details)."
So something is definitely amiss.
and here are my injustice 2 settings (i havent changed anything here at all)
display mode fullscreen
screen resolution 2560x1440 16.9
vsync off
dynamic resolution off
frameskip off
texture quality Very high
aa mode TAA
aniso filtering x16
bloom high
motion blur high
lighting medium
shadow quality high
shadow technique msm
ss reflection on
ambient occlusion high
subsurface scattering high
patricle density very high
particles mode gpu
Just want to get a clearer understanding what you mean by "jerky when you pan left to right and vice versa or action goes fast the picture jerks"....
In terms of frame rate, have you already check how it is? Is it a case of normally the frame rate is fine, but when it "jerk" it quickly tanks for no apparent reason, and then recover after 1-2 seconds right after?
doom im getting 90-100 fps according to ab but the ms number next to fps goes for 9ms-40 when i pan the screen and it doesnt look like its losing FPS to me
Wrote before. MSI AB & RTSS overlay create issues with AMD cards especially with Vulcan.
You need to remove it and use the AMD overlay
