Velka 7 v2?
19 Oct 2002
Is there any way to face the GPU the same way as the MB, there doesn't seem to be a way to skrew the card in with the io facing the back?
The new Velka 7 (which is the revision of the Velka 5 v1.1) had the MB rotated so the IO faces the back, the GPU still faces upwards but is hidden and uses 90deg DP/HDMI extenders to route the display outputs to the back too. Its impossible with the vertical layout for the GPU to face the back naturally.
The other option if you want the GPU to face the same way as the MB (i.e. out of the top) then you will need to find a used Velka 5 v1.1.
Well none of the Velka cases (7, 5 v2, or 5 v1.1) would fit a 3 slots GPU anyway.
The only cases that meet your criteria would be
1. Formd T1 - not available to buy right now.
2. Loque Raw 1 - in pre production.
3. Lian Li/Dan A4 H2O - in pre production.
Otherwise have search on Taobao for Chinese clones.
Good luck and well come to the world of SFF PC. Lol
Meshilicious would work as well. Though it could be ages before we see that case in Europe (and it's a lot larger than the others mentioned).
CL530 Console Style Mini-ITX PC Case for 3-slot GPUs is cool the
Meshilicious has the power button & USB on the top, You would have to sit it on your desk as a tower, or have the oddness of a on the side power button & usb ports. Just would like a slim ODD cutout in the CL530 too.
