VENGEANCE Series™ 650M HELP PLEASE
Permabanned
8 Jan 2017
Hi there I have this PSU but misplaced some cables I’m getting a 3080 trio so it requires three 8 pins which the psu can do however I need another 8 pin cable for my psu.
I have a set of cables from my SF600 psu would these be compatible to use ? Are they both type 4 ?
On corsairs website it states - “
  • Only compatible with 8pin PCI-E, 4pin Power and 5pin SATA Power cables:
    • CS-M
    • CX-M
    • TX-M (GOLD & BRONZE)
    • VENGEANCE-M (BRONZE & SILVER)”
    • So hoping everything should be ok
Your best bet is to contact Corsair Customer support and see if they can supply you some spares.
But I would also say that PSU might not be up to running that card if your other components are of similar performance.
It seems a 850 W is recommended with the transient spikes an RTX 3080 can hit go to almost 500 W. Just for the card.
