Venice cores
28 Dec 2004
Derry
Oh my word, I've just installed an A64 3200, it's using a Thermaltake SI120 for cooling so I thought I'd overclock it a little, straight to 2.4ghz and under load the CPU temp is still under 35 degrees, I'm stunned, can I expect more from this processor?
At the moment a cheapo Asrock 939SLI-Esata2, I'm up to 2.7ghz now, voltage adjustment is set to auto, cpu temp is 32 degrees, up to 34 under load and it appears to be exceptionally stable. It takes a bit to impress me, I was expecting the CPU/Motherboard to just give me a stable system and certainly didn't expect it to be such a good clocker.
lol there awesome clockers, mine eventually packs in at 2.9! running at 2.6 all the time now though, its 100% stable, fast enough for anything i do and running very cool with my zalman CNPS9500 monstrosity, only overclocking problems i have had were motherboard BIOS problems, glad you like the processor though
2.7 doesn't (for some obscure reason) let me connect to my wireless lan, lowered down to 2.6 and it's fine, still, can't complain.
Turns out the Asrock board (even with the latest bios) only let's you wang a maximum of 1.45 volts into the processor so I've reached a ceiling at 2.6, might try one of them ocworkbench unofficial bios's, or buy a new board.
Hmmm I have a similar problem at 2.92Ghz. Nice clocking you got there mate :)
Mul
Lower the htt multi (i know its not over 1000 but it still worked for me)
