Venice or San Diego?
12 Mar 2006
I'm looking to get a new processor next week and I've been looking at getting an A64 3700+ San diego or an A64 3800+ Venice. which of these is the better one, I know the 3700+ is slower but its got 1Mb of Cache, is this important for speed in games? I'm also getting the asrock dual sata 2 mobo
Cheers.
id go for the 3700 because you can overclock to increase clock speed but you cant add cache. Alternatively you could spend a bit extra and order one of the 3800x2 dual core cpus. This would not be quite as fast in single core applications at stock speed but would be much better in multi threaded applications and at multitasking.
For an extra £2 over the retail 3700sd you could get an oem 4000sd that has a 12x multi over the 11x on the 3700 so should help clock that a bit higher.
Don't do that, some of the 4000's on sale here are clawhammer cores, not sandiegos.
Go for the 3800 X2 or the 3700 SD :)
Cyber-Mav said:
go x2. its best option now.
If you can get hold of one that is. Place an order now if you're considering, gibbo's doing the best he can but they're still selling at the speed of light
i seen online retailers which have the x2 3800 in stock selling it at £110 inc vat. so it is a very easy cpu to get a hold of but your wasting time by not ordering it.
If you can't get the X2 3800, get the San Diego over the Venice (1MB L2 Cache is better than the venice 512kb).
Why are you all advising him to go X2? He said he wants it for gaming, and most games at present are single-threaded, so UNLESS he has a large number of background applications running while he's gaming a higher-clocked single-core would surely be better, wouldn't it?
If that is the case ocuk are falsely advertising them as they state san diego on the site, so if it is no good you could send it back and demand your money back.
Got to agree with that, i'm also under the impression that a well clocked single core cpu would be better than a clocked 3800 in games :confused:
Would be nice to see some benchmarks to say for sure either way
If that is the case ocuk are falsely advertising them as they state san diego on the site, so if it is no good you could send it back and demand your money back.[
Oem ones state "san diego" at the moment, but the retail ones don't.
krooton said:
Oh no! I got a retail, how much worse is the CH to the SD? :(
It has a lower quality memory controller, it doesn't have sse3 optimisations, its not built on the 0.9nm silicon & hence needs more juice & won't normally o/c as far.
If you are running at stock you won't really notice any difference unless you are trying to run 4 sticks of ram.
Curse my impulse buy and curse OCUK for the deal of the week :(
I didn't even want retail, OEM is fine, guess this was their way of clearing stock that the fundis wouldn't buy *sigh*
Is there a possibility of my retail being SD?
I can tell without checking the stepping right?
Gah, will have to dismantle, and I only put her all back together again on Monday :(
possible yes. CPU-Z will tell you what version it is.
