- 13 Feb 2009
- London
Is the paste that comes with the Venomous X anygood ? better then the mx2?
Cheers.
Cheers.
Cheers.
I've got the Venomous arriving tomorrow, was just going to use the MX2 paste that I have...
P.s, what fans you running with it ? i'm going to order 2 of these
http://www.overclockers.co.uk/showproduct.php?prodid=FG-059-AK
Assuming you have an Intel rig, the AS5 will benefit -greatly- from the pressure-bracket that comes with the VenomousX. When properly applied the AS5 is exceptional at what it does but often suffers due to its thickness when using more flimsy/non-pressure mountings.
That being said, both pastes are top-tier so either will serve you well.
- Ordokai
Yeah intel i7.
So for this cooler, the silver 5 would be better then the MX2 ?
The site says do a line. i've always done it this way. would you say this is better then the spread way ?
So you still think AS5 would be better then mx2.
the as3 in the vid didn't spread so well.
It's down to personal preference really. I use MX-2 now as there's no curing time needed and it's not electrically conductive either.
The Chill factor 2 that comes bundled is actually very good. Very similar to the MX-3 in terms of performance when I checked for myself.
Interesting, then of course it's a good idea to give the bundled paste a chance. You can always reapply your own after if the results don't appease.
- Ordokai
Yeah I myself gave it a try after I had run out of MX-3 and found that it was very good. I've got so many different tubes though so I might do a round-up at some point. Tuniq have their new TX-4 and Thermalright also has the Chill factor III now.
soon
lol
