Veoh Web Player (?????)
11 Jan 2008
Nowhere
Why won't Veoh Web Player work? It's used for watching videos longer than 30 mins on Vehom before this they had VeohTV which worked great, But this, arghhh,
I've installed the application twice but it fails to login, there is also an option to sing up but that also fails.
However, the accompanying Video COmpass application for firefox seems to work fine. But now no videos on Veoh will load, at alll.
Any help please? Veoh suggests its my firewall, its not blocking anything and I have even switched it off and still I have a problem.
This is annoying because there seems no obvious damn solution.
:mad:
Heres a shot of what it says when I try to login or when I try to do pretty much anything:
Did you turn the firewall off and then install it, or was the firewall up and running when you installed?
