- 22 May 2013
this suddenly happened when I booted my computer today
I turn it on, it goes past standard bios screen then it's stuck saying "verifying DMI Pool Data"
I've tried:
1. checked all cables and made sure harddrive is connected properly, which it is - it can be detected in the bios settings
2. reset all cmos settings to default
3. removed the cmos battery for an hour to completely clear the cmos
4. went into PNP/PCI configuration and enabled reset configuration data
5. removed cd-drive and everything else but the harddrive
6. tried a new harddrive - nothing
I thought I would try reformating the harddrive, so I plugged in the cddrive again to try and format it using windows 7 - however if I tried to boot with cd-rom I get the verifying dmi pool data.. again
I tried to update the bios but when I try to boot from the usb drive I get the verifying dmi pool data again
any ideas?
I've tried:
any ideas?
