Vertagear Casters Stem diameter
4 Aug 2006
Hello
I need new casters for my (old but comfortable) chair. I have my eye on these. From my research the two main pin stem sizes are 9.5mm (3/8 inch) or 11mm (7/16 inch)
I require the smaller 9.5mm size, but I can't find the info on the stem size for these casters.
Would a staff member be able to confirm the measurement possibly? Or could a member please measure if they own them?? I could always return them if they don't fit but would rather avoid that hassle if possible.
NB - the info about the 6mm shaft is referring to the shaft which holds the wheel together, not the grip ring stem size.
