Vertagear chairs
I've got the SL5000 and it's a good chair. The chair assembles ok but watch you don't over-tighten the screws on the plastic covers on either side as they will break if the screws are too tight. The three part gas lift plastic cover also broke on mine when fitting and I never got this replaced.
I emailed OCuK and they never responded to create an RMA to replace the broken plastic covers so I emailed Vertagear direct and eventually I got sent replacements from a distributer in the U.S.A.
Is there anything I can help with?
Bailey
Bailey
Thanks, but I've sorted it now. My initial request to OCuK went un-answered and to be honest I could have chased it up with you but I emailed Vertagear direct and they eventually sorted it out. It was low down on my priority list anyway.
Cheers.
I used the seat configuration mebob on Vertagear website and after i'd inputted my details, it said the most suited chair for me was the SL2000 so bought that from Chug
