Vertical Dual Monitor Mount/Stand
26 Feb 2007
Leafy Cheshire
Can anyone recommend a stand for 2x 27" Monitors mounted one above the other, with the top one tilted down slightly? Many seem of dubious quality.
I use a Duronic DM35V2X1 (from the rainforest) to hold two 22" monitors. It's solid, and doesn't sag (top monitor is angled downwards slightly)....might be worth a look for you?
