- 14 Jul 2005
- Birmingham
Bit bored so planning my next build as I'm planning a big PC refresh when the next gen stuff appears.
Have seen vertical GPU mounting in some photos here and it seems to have some significant benefits not least preventing GPU sag and enabling the card to be seen better especially if its a looker or you've gone for some RGB fans on it.
However it doesn't seem to be a common choice outside of big showcase type builds and I'm wondering why?
I know you need the extra mount, although it seems some cases even come with these and with dedicated vertical PCI slot plate covers sometimes two and sometimes three slots wide in wider cases.
Why isn't this more common?
With the suspected size of the new 3000 series cards, sag could be a much bigger problem as well.
Which cases offer the best vertical mounting solution?
