I built 2 pc's of exact same spec recently. One is working fine, the other is freezing as above, and the PC has to be rebooted. It then lasts a random amount of time before it happening again.
I took the motherboard / ram back to shop for testing. They said that they couldnt find a problem with it after a couple hours testing. They said that it could be a problem with drivers or a bit of software causing issues, which I call BS.
Is this a hardware fault, or a software fault? Does anyone have an explaination as to what may be causing it?
Thanks in advance.
