Vertical monitor mount 35inch+27inch with swap option
28 Jul 2014
Hello guys, I have a small question for which one I can’t find any answer yet. I need somehow to mount 2 monitor vertically One of them is 35 inch, 2nd is 27 And I am looking for an option to swap them when I need so. Let’s say move 35 on top and 27 set as primary, or opposite way Currently I have 2 monitor arms , it’s ok when I use 35 as primary, but when I switch to 27 I literally don’t have free space on my desk
Dual Monitor Stand Stacking with Quick Release
If i had to use one it would be Ergotron LX dual stacking arm
Thank you! I just checked this Arm, a bit expensive... But if not gonna find another option i will go for it, need to check my ultrawide weight, as there on 9.2 kgs max :(
I believe the Amazon basics arms are rebranded Ergotron ones, so can save a few quid there. I know its the case for the single LX ars, wouldn't be 100% certain the same is true for the dual stacking ones.
