Probably a horribly stupid question, but I've noticed that on some websites, after I scroll down a bit, the vertical scroll bar slides off the screen, and won't come back until I move the cursor away from where it was and then go back to where the scroll bar should be.
It then slides back onto the screen, I can scroll to where I want, but the bar doesn't stay there, slides off again and I have to do the same thing again.
I presume this is intentional by the website designer, but is there any way to stop it happening?
Probably a setting somewhere, but I can't find it!
Thanks in advance!
Thanks in advance!
, so don't use Firefox - I tend to stick to what I know!
