- 12 May 2011
- Southampton
I'm thinking of watercooling my cpu only to reach higher overclocks at cooler temperatures with less noise. First of all, is this possible with the pre set up cpu watercoolers like the h60i h80i h100i?
Secondly, will a h100i fit into my case? I have a shinobi core case with no window. It isn't the xl one but does have two top fan mounts.
Thirdly, if I upgrade to Haswell in June, will a watercooler I buy now fit on a 1150 socket?
Thanks for your help!
