After building up my PC have been going through the numbers in the various sections and they don't quite add up. Any assistance in making some sense of this would be appreciated.
The Mobo is a Gigabyte S3 running a Conroe E6600 Core 2 Duo rated (supposedly) at 266/1033.
On boot up/post the system check shows a clock speed of 266 x 9 = 2400Mhz.
However BIOS under MIT only shows the clock frequency set to 200Mhz x 9.
The Gigabyte software utility I-Tune shows 266 x 9 = 2400Mhz.
CPU-Z however shows the overall speed as being 1600 with the multiplyer only x6 which would also give a clock speed of 266.
Raising the speed from 200Mhz to 266Mhz in MIT has increased temperatures by @ 10C and raising over 266Mhz then starts to show an overclock situation in Post and I-Tune (but the temperatures look as if they are not sustainable).
The $64,000 question is which set of figures should I believe or have I just not set things up correctly to start with. I'm also worried what speed my CPU is really running at if the FSB figure in MIT is set to 200. Is the thing actually running underclocked? In which case why would POST and I-Tune register the correct speed.
Help....!
Help....!
 Had to clear CMOS to recover. Not prepared to trash my system by pushing further. At 281 x 9, i.e. 2.54 Ghz, temps were pushing 60c for CPU and 62-63c core under Prime and that's with just one session running.
