Very First Build spec
14 Sep 2008
Stoke-on-Trent
Hi every one this is my very first build with OcUK and and my first post WOOP WOOP and i just want run past you my spec it will be used as a HTPC and some light gaming all alterations and suggestions are welcome thanks
(i will add a blu ray drive a 8800gts card and also another 500gb HD)
my main concern is the PSU and whether everything will be compatible with the mobo
my.php
[/URL][/IMG]
i'm not a hardcore gamer no longer than a hour at a time and not everyday also why change to intel (i'm New) thanks for the replies
Save £40 and get this. The 300 doesn't need any extra fans, use the stock cooler at stock speeds and fit a better cooler when it seems slow and over clock. (should get 3GHz)
thanks for the replys just a few more queries has anyone used the mobo and got a good HD quality not much in the reviews about HD you see and this is the main reason i chose this board also thinking of using windows media centre and i heard that vista pro has media centre aswell i'm tempted to stick with xp because of all the VISTA SUCKS threads lol
