Hoping someone can help as I'm out of ideas. I removed my water cooling to give it a clean and refill putting a thermal take frio advanced cooler on while I sorted water cooling. When I boot up temps are hitting 90° and the system shutsdown. Still using the MSI x79a gd65 board and all settings are default I've checked both the CPU and socket both are fine. I checked the seating of the cooler and that's also OK tim coverage is near full but not overly thick. Right now the PC will not run unattended and to get to desktop I'm having to delay the overheat shutdown. Temps go down as low as 42° then suddenly spike up hitting high temps long enough to shut the system down. All this with both case sides off on a corsair 700d ambient room tempreture between 19 & 23°'s.
All I can think of now is something within windows is creating problems but there is no malware or viruses according to mbam pro or kaspersky. Hoping someone has some ideas as its driving me nuts not being able to play a game to chill out. Due to money issues gonna be a few weeks before watercooling can go back in but surely i shouldnt be having this level of problem. Thank for any help offered anything is appreciated.
