- 4 Mar 2009
I'm trying to overclock this cpu I just bought but at stock settings and core voltage at 1.1750 bios, 1.120 in CPUZ, temperatures are reaching 67 degrees C at full load. Idle temps read around 52-53 minimum.
Should I be worried, considering I have a noctua heatsink with 2 fans either side blowing hot air out of it?
I'm using both CPUID Hardware Monitor and RealTemp for checking temps and they are both within 1-2 degree of each other.
P.S. I have taken this one up to 4.37Ghz on air, for benchmark purposes but with the higher voltage required my temps got too high for my liking. Something like 62 idle and 74 load.
Anyway i'm sure this isn't normal so I've come here to ask for ideas. I've already tried reseating the heatsink once, and reapplied the thermal paste.
Oh and if I push down on the heatsink with my hands the temperature will only drop by max 2 degrees. I tried this in a number of directions.
