I hadn't checked my CPU temperature for a long while since the other day and noticed it was higher than I expected. I've just checked again today and it's up at 73 C while the motherboard is only 30 C. About a year ago when I used to check more regularly, the CPU would be no more than 50 C, usually around the 40 mark. Given the CPU is that much higher than the motherboard I'm thinking something could be up.
It's an non-overclocked P4 3.0GHz and is around 32 months old now. The fan appears to be running normally but might be dusty. I also have a rear 80mm Coolermaster Aero fan and another standard 80mm case fan on the side panel.
What's happening to the poor thing!?
its still going strong today, all be it with better cooling.
