Very long shot, cable box injected into network. Any one know a way?
31 Jan 2011
Hampshire
Ok so here is my dilemma,
My other half has bulsatcom (bulgarian cable tv) she pays for this and we are happy to continue doing this. In the us they have the hdhomerun hd4 so you can watch us cable subscriptions through plex. In the uk we can do this with the freeview system but not cable subscriptions (annoying) the bulsatcom comes down a regular skydish and into a hd reciever. Now if i could plumb this into the plex system and share it around the network like hdhomerun... that would be spectacular. I have tried adding the iptv feeds into plex but it just cant manage to play them for some reason. I can use iptv app and that works by giving it the online addresses of the channels but i think this is not necessarily legal even though i pay a subsciption to the service so one could argue im paying for it does it really matter how i view it.
If there a way to some how convrt the actual "sky box" if you like to feed ovr my network and if possible into plex tv channels but if not another way? I have been looking at slingbox but this seems more focussed on sending out to mobile devices. I have no issue paying for my subscription to the service but would love a hdhomerun box like the us one that takes the subscription card and shares it over you internal network.
All ideas welcome and hope i have explained well enough what im trying to do.
you can get satellite tuner boxes that output to your PC, which you can then publish a stream on the local network - its just if you can take your subscription onto that I guess.
this would be ideal, If i could chuck the tuner card into that. Just need to find one that will work with that particular provider i guess. you would think these days they would just let you stream a genuine subscription considering people just do it anyway without paying... never mind.
I'm using a HDHomerun Connect through Plex for freeview at the moment and all I'd say is don't put all your bets on Plex as a DVR service as it is still very buggy. Getting better but not stable enough to be trusted as I've had a few recordings freeze up and then lost when I have to reset the media server, seems to have issues letting go of a tuner. I'm sure they'll work it out but I'm tempted to pay the $30 and just the use the HDHomerun DVR service instead.
Couple of things to check, does Plex support your provider for EPG data and does your provider encrypt channels as that can cause a lot of issues.
