- 20 Aug 2012
- Greater London
Right, so i'm a bit of an amateur at building PCs, and this is my first one. The problem is that i have is that i have 7 fans (including psu and gpu fans) and they're REALLY loud. it actually sounds like there's a big fan that you find in a car engine in the case, and it's kinda starting to get on my nerves.
The cpu and chassis fans are all running at around 2000rpm (give or take), which probably doesn't help, but at least its cool
My question is, is there any way that with very little money, i can make those fans quieter, without compromising the temperature (thermal matting could increase cpu and mobo temps?). the case came with rubber grommets for the fan screws, but i'm not sure whether they will help or not...
it's running at about 2300rpm constantly, and it's not exactly the quietest fan...
