Very odd FPS drop issue. Brainy people please help!
1 Aug 2020
Hello,
I've got a very strange FPS drop issue that is beyond my level of understanding, so I've come in search of brainy people for help! Sorry if I've posted in the wrong section but I felt this was the best fit.
Apologies in advance for the long read, you might need some caffeine.
Original components;-
NZXT S340 Elite case
Asus Strix Z370-F motherboard
i3-8350k CPU
Arctic Liquid Freezer 120mm AIO CPU cooler
Crucial 256Gb M.2 SSD C drive with Windows 10 Pro 64
Palit RTX 2070 Dual GPU
EVGA B3 550W PSU
WD 1Tb M.2 SSD D drive
I may be old enough to know better but my son badgered me to play Fortnite with him a few months back and now I'm hooked. For me it's the building element that sets it apart from any similar style game I've played and it's the first game since Call of Duty 2 from 2005 that I keep wanting to play. Anyway, the issue...
On the evening of Friday 24th July I was playing Fortnite at a constant frame-capped 144 FPS at 1440P. For a few days prior to that I'd noticed when flying high up in the battle bus that some of the distant objects didn't appear quite as graphically rendered as usual, or at least that's what I thought. With that in mind I decided to update my motherboard's BIOS and Nvidia graphics driver for my Palit Dual RTX 2070 GPU, as what harm could it do?!
I hadn't meddled with my motherboard's BIOS before so it would have had the original BIOS from new. I do however update the graphics driver maybe every few months, and have never had any previous issues.
Both the BIOS and graphics card driver (451.67) update appeared successful so I loaded up Fortnite again having been playing it only 30 minutes earlier. I was instantly met with huge frame drops that I wasn't used to. Often the drops were down into double figures, going as low as 15 FPS and regularly under 60. The drops aren't gradual either, they'll go from 144FPS to 20 in an instant. Due to my Fortnite addiction I'd bought a 144Hz monitor from Overclockers about a month ago in a desperate attempt to gain any advantage over my son who plays on a 60Hz TV. The drop in FPS is very noticeable in the form of stuttering and it definitely affects gameplay making me even worse than usual.
I hit Google in the search for an answer and formed the opinion that the most likely culprit was the BIOS update. That sent me on a mission to roll back my BIOS, which didn't help no matter which version I used. The only other thing I'd meddled with was the graphics driver so I uninstalled the latest version and tried various older drivers (including one stored on my PC that I'd previously used that used to work perfectly), each one giving the same FPS drops. I have used Display Driver Uninstall each time to completely clean the PC of any previous GeForce driver before installing a different version. I then reinstalled the latest game-ready driver again, version 451.67.
I checked the startup apps and prevented anything from starting up that wasn't necessary.
I loaded up CoD WW2 and the frame-rates were fairly constant, which was all the more confusing. Regardless of my testing I was convinced it was a motherboard BIOS issue so I treated myself to a new motherboard, processor, CPU cooler from Overclockers and a 1Tb M.2 SSD from elsewhere.
New components;-
Asus Strix X570-F motherboard
Ryzen 5 3600 CPU
Arctic Liquid Freezer ii 240mm AIO CPU cooler
Sabrent 1Tb M.2 SSD C drive
Probably not in the most sensible order but after ordering the components I then installed my RTX 2070 in my son's PC. I was very surprised to see the frame-drop issue transfer to his PC, leading me to think my GPU was at fault after all. I hadn't suspected the graphics card as it's only eight months old and it appeared to be fine with CoD WW2, although maybe it's not as graphically demanding as Fortnite possibly and doesn't stress the GPU as much? I then tried the GPU back in my PC and installed Counter Strike as it was free to download on Steam. The FPS in Counter Strike would peak at over 300 and go down to around 130 but this was a more gradual rise and fall rather than an instantaneous drop so I assumed that it was normal behaviour depending on how graphically demanding a particular scene was. I may be wrong however.
I also ran Furmark GPU benchmark software and my GPU appears to be working perfectly. Its peak FPS was 99 with a minimum of 96. The highest temperature I've recorded of the 2070 during either gameplay or testing is 72 degrees centigrade. The PC case is on the floor in a cool room, has plenty of space around it and good airflow within it. The PC was already clean inside and out before this issue began but I still cleaned all the dust filters just in case.
The new components arrived on Tuesday and I installed them as I had the day off. I have not messed around with the new board's BIOS in any way!!!!!! I installed a fresh copy of Windows 10 Pro 64 on a new 1Tb M.2 SSD C drive. I then installed the latest Nvidia driver 451.67 followed by the Epic Games Launcher and Fortnite, all on the C drive. To my dismay and surprise I was still experiencing the same frame-drops. I have tried various Nvidia drivers since but always get the same FPS issues.
I've tried searching Google to see if anyone else is currently experiencing similar issues but I appear to be alone. I'm wondering if there's a strange issue with Fortnite that's maybe only affecting my exact model of GPU as I think I've pretty much ruled everything else out. The frame drops are particularly bad in the lobby but still constantly affect the game too. I've done a lot of research and testing, and I'm out of ideas. Initially I thought it can't have been a coincidence that Fortnite started running poorly directly after a BIOS and GPU driver update, but since then I've rolled back the BIOS to various versions, swapped GPU drivers, replaced the motherboard and CPU, installed a fresh copy of Windows on a new C drive, changed graphics drivers again, and tested my GPU using Furmark and a couple of games, which is telling me it might actually be an issue with Fortnite and my GPU, or something even stranger.
I contacted Epic Games expecting to wait a few days before getting a generic not remotely relevant automated reply telling me to turn my PC on and off but on the contrary they've been amazing. I get a reply each time in an hour or less and they've bent over backwards to help. They've had me send back DxDiag files, logs from the Epic Games Launcher, Client/Game logs, an MSinfo file and videos of gameplay with the FPS counter showing the drops as they happen. I could not ask for more and they're continuing to help me. But... as yet they're as stumped as I am... and that's why I'm here, in the hope that someone might be able to help point me in the right direction please having experienced something similarly odd.
If you've actually made it this far and read my whole post then thank you very much, it's greatly appreciated. And huge thanks in advance to any advice you can offer, regardless of whether it works or not as anything's worth a try.
Justin
Hello Chaparral and Poneros,
Thank you both for taking the time to look for an answer. In the absence of females Chapparel I'll have to make do with you guys... no pressure!
I've just clicked the link and it makes for an interesting read, and it proves I'm not alone, which is oddly comforting.
I'm not sure if I've previously read that thread but I have seen similar. Most of the posts are a year or more older but there is one that's only a month old, so this appears almost to be happening at random and not across the board, and not at any one specific time. Having said that, when Googling earlier in the week I did find a group of complaints from January of this year and October of last year when there appeared to be definite issues.
When Googling I was expecting to find similar issues happening to a number of people right now, which I couldn't find evidence of. It also doesn't appear to be GPU specific, or even specific to Nvidia or AMD. So maybe it's pot-luck and just a bug in the game itself that may or may not affect you. It has to be something to do with the combination of the game/driver/GPU though as replacing the board and CPU didn't make a difference.
Sadly, as much as I've seen people complaining, what I haven't found is where a similar issue was resolved and therefore how it was resolved.
Poneros, I'll have to double-check now that I've replaced the board and CPU, but before I replaced them when the issue first began the CPU was almost at 100% and seemed normal. As for the GPU though, according to Asus GPU Tweak ii it was running at around 100% but if you believe the Windows 10 Task Manager it was running at about 30%. I thought maybe that could be the issue until I read that the Task Manager monitor can be wildly inaccurate, so GPU Tweak was probably correct. I'm not home until later this evening but as soon as I get a chance I'll check their usage again and report back.
Thank you both very much for your time and help.
Justin
Hello to you all,
sorry for the late reply, I worked all day Saturday and did family things yesterday. Thank you all very much for your help.
EastCoastHandle. Thank you very much for your suggestion. I tried it and was quite excited as it did sound very feasible but unfortunately it didn't work on Fortnite so I reverted the settings. Thanks anyway as definitely worth a try.
Jacky60. Don't you just hate it when that happens! :)
Barnacles. You know what, I did try it but I've done so much testing I can't quite remember exactly what happened. I've got a feeling it may well have stuttered a bit on mine but I'll have to try it again when I get some time. I have since replaced the motherboard and CPU though. I will definitely give it another go.
D1craig. Never heard of a tracert before but I've Googled it. I ran a ping and tracert test in the Command Prompt using what I think is the correct European Fortnite server address as a destination and got these results. Haven't got the foggiest what any of it means however :(
C:\Users\jdigh>ping qosping-aws-eu-west-3.ol.epicgames.com
Pinging qosping-aws-eu-west-3.ol.epicgames.com [52.47.107.154] with 32 bytes of data:
Reply from 52.47.107.154: bytes=32 time=15ms TTL=46
Ping statistics for 52.47.107.154:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 15ms, Maximum = 15ms, Average = 15ms
C:\Users\jdigh>tracert qosping-aws-eu-west-3.ol.epicgames.com
Tracing route to qosping-aws-eu-west-3.ol.epicgames.com [52.47.107.154]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms RT-AX92U-C880
2 4 ms 4 ms 4 ms 170.16.10.44
3 * * * Request timed out.
4 8 ms 8 ms 8 ms 31.55.185.180
5 8 ms 8 ms 8 ms core1-hu0-15-0-6.colindale.ukcore.bt [213.121.192.8]
6 13 ms 14 ms 9 ms peer7-et-0-1-6.telehouse.ukcore.bt.net [109.159.252.166]
7 14 ms 14 ms 29 ms 99.82.178.72
8 * * * Request timed out.
9 * * * Request timed out.
10 14 ms 15 ms 14 ms 176.32.106.180
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 15 ms 15 ms 15 ms 52.46.94.98
16 17 ms 19 ms 15 ms 52.46.94.111
17 17 ms 15 ms 15 ms 52.46.93.125
18 15 ms 15 ms 14 ms 52.46.93.12
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 14 ms 14 ms 14 ms ec2-52-47-107-154.eu-west-3.compute.amazonaws.com [52.47.107.154]
Trace complete.
LeMson. Of course, sorry about that. 2x8GB Corsair Vengeance 3200MHz DDR4. I've now used DOCP/XMP whatever it is in my motherboard's BIOS to get the memory to run at its rated speed. CPU-Z tells me;-
1596.8 MHz
FSB:DRAM 1:16
16.0 clocks
18
18
36
75
1T
Again, no idea what any of that actually means!!
Epic Games asked me to upload an unlisted video to YouTube showing the frame-drops, which I did just before this reply. I used Asus GPU Tweak at the same time with an OSD showing various details of my GPU, CPU and memory while the game's running that will hopefully help them.
Thanks again to you all, I really appreciate your help.
Justin
Hello to you all,
IT'S FIXED!!!!!!
Last night I stumbled across a channel on YouTube called Adamx. I was listening to one of his videos when I heard him mention something about FPS drop issues on Fortnite due to audio settings. I immediately remembered recently changing an audio setting in Fortnite. I couldn't remember exactly when I'd changed the setting but felt it was likely to have been the same night I'd updated the BIOS of my previous motherboard and graphics card driver.
I watched the rest of the three minute video and Adamx shows the Fortnite settings audio page. He mentions setting the Sound Quality setting to low and not high, as it can adversely affect FPS.
Adamx
How To Fix FPS Stutters & Audio Dropouts In Fortnite Season 3!
https://youtu.be/dQy4pprE_zE
I was working a night shift last night so I couldn't test it out until I'd been home for a sleep. But... he's absolutely right, it works and my FPS is now once again sat at 144 and the gameplay is silky smooth.
I completely forgot on the evening of the 24th that I'd changed my Sound Quality setting from low to high. I forgot because I'd done a BIOS update and graphics driver update, so they clearly drew all my attention, and why would anyone suspect that an audio setting could cause FPS drops?
I checked my son's PC too and his Sound Quality setting was set to high, which is why I encountered the same issues on his PC when I installed my RTX 2070 into it. Also, when I uninstalled and reinstalled Fortnite on my PC, Epic's servers remember all my my settings, so Sound Quality was always set to high once I'd set and applied them on the 24th. However, Sound Quality set to high doesn't seem to affect his PC when used with his GTX950.
So, it appears to be that with certain graphics cards on Fortnite, if you have Sound Quality on the audio settings page set to high it can cause sudden FPS drops. How strange is that?
I've just replied to Epic, who've bent over backwards to help to be fair, just to make them aware so that they can help others like me. Surely the department I've been in correspondence with aren't aware or they would have mentioned it to me.
Anyway, I'd like to say a big thanks to all of you who've taken the time to make a suggestion, we got there!
Justin
Hello D1craig,
Thanks, I've now uninstalled the Nvidia HD Audio driver too. I use a displayport cable to a speakerless monitor so having the Nvidia audio driver was pointless, which I hadn't realised until you mentioned it.
Anyway, it's all working well again now so I'm going to try to learn not to meddle with things unnecessarily!!
Justin
