Hi All,
Was wondering if someone could help me with a very odd power issues I'm having.
First sympton
1) If I have my PC unplugged, when I plugged in power it need's about 5 mins before it will power up. It's very odd like a dynamo effect you can see the fans starting and LED';s going on then it powers off after about 1/2 sec, does this a few times then when it appears charged it powers on. This started about 3 months ago and previoulsy the build had been fine.
2) When I shut down the PC is turns itself back on after about 2 minutes of being off, this sympton has only just started.
My first thoughts were a CMOS issue as it sometimes reset the bios back to defaults.
My 2nd was the Power supply may be on it's way out, if I was overloading the power in the machine surely it would power off during peak use. At first I thought it was due to my PSU only being 500w but I'm sure these symptons wouldn't happen as it seems fine once it up and running.
My spec is as follows
Abit aw9d-max
Thermal take 500w Power supply ATX 2.0
BFG OC 8800 GTX
Creative Fatality Soundcard
Intel q6600 GO
4 * Sata hard drives using hardware raid
2 * CD rom
4 * Geil 1GB DDR2
First sympton
Abit aw9d-max
BFG OC 8800 GTX
Intel q6600 GO
2 * CD rom
4 * Geil 1GB DDR2
