I have a pc which for no apparent reason has reverted both the user accounts on it to default settings.
Its exactly as if someone went and deleted the user accounts and made two new ones under the same names.
However old account settings are still in folders under the account names with all the documents, desktop backgrounds etc, and its created two new folders with the username.pcname as the name on the folders, and its also created a temp folder in there for some reason.
Any details, screenshots, anything that might help you help me solve this, let me know. Its running xp, fairly old machine, very clean copy of windows only recently formatted.
Of course i can copy the stuff from the old user folders and into the new ones and be done, but theres nothing stopping this happening again, as it seems as if it happened by itself.
What on earth is going on?
how can i fix it?
Thanks.
how can i fix it?
Thanks.
