Hi,
Heres my wireless setup. I have a telewest cable modem connected to a netgear rangemax wpn824 router. 2 pcs connect to the router wirelessly using wireless G technology. 1 pc connects using cable (its next to the router)
Questions.
I have constant problems with the wireless connection. These include poor signal. i get barely 40% signal strength in my room? which is only 4-5 meters from the router with 1 wall inthe way.
The router sometimes refuses to pick up an IP address from the cable modem. I dont know whos at fault here but my old netgear wireless router didnt seem to have this problem.
The second pc also has the same poor signal problem. Even when the distance is reduced to 1 m in open sight the signal strength is still like only 80% percent.
I have recently bought new 9bdi gain antennas and that hasn't made an ounce of difference from what I can see? these things are a good foot long as well.
PLease help !!!
I have also bought something from the bay which allows me to remove the antenna and position away from the pc.
ARGH this is stupidly retarded !!!!!!
Questions.
PLease help !!!
