Make sure both side panels have been removed from the case. Inside the case on the front panel there are three clips, which are attached to the left side of the front panel, push them out to release them from there holdings, then the front panel will be easily removed..... Failing that on the other side of the front panel there are also another three smaller clips which can be pushed out as well to help. On my first attempt I needed two pairs of hands to hold all the clips out on both sides... Job done.
