Very quick question (Re: Gigabyte 965P DS3)
17 Sep 2006
I have a radeon 9550 AGP graphics card. Would I be correct in assuming that it is not compatible with the Gigabyte 965P DS3 motherboard ?
If not, could anyone recommend a compatible motherboard in the £100 price range ?
for a conroe ud b lucky to find a agp compatible board i think a few ASRock boards provide agp and pci e though
AGP is pretty much obslete now so I wouldn't buy any new PC based on AGP
If you're not gaming then get an X300/X1300/6200/7200 or whatever's cheapest for about £20 in PCI-E and get a PCI-E motherboard. Far more choice and if you wish to upgrade the graphics card at a later point you can do so easily
