Very quick SLi Question
30 Jun 2003
Berkshire
Ok manager has asked me to build a new pc for him, he says ideally needs a comp with 4 monitors! if i get two graphics cards with pci-e sli'd will i be able to use all 4 DVi connections?
nope hes waiting four, lol
heres the spec im looking at
-XFX 680I LT edition SLI Intel Socket 775 Nvidia motherboard ATX
-Intel Core 2 Duo E6750 2.66GHz 1333FSB Socket 775 4MB Cache Retail Boxed Processor
-Corsair 2GB Kit (2x1GB) DDR2 800MHz/PC2-6400 XMS2 Memory Non-ECC -Unbuffered CL5(5-5-5-12) Heat Spreader Lifetime Warranty
-2x XFX 8800GTS 320MB DDR3 XT Edition DVIx2 PCI-E
-NEC Optiarc AD-7170S-0B 18x DVD±RW/DL/RAM Serial ATA Black - OEM
-Seagate ST3500630AS 500GB Hard Drive SATAII 16MB Cache 7200RPM - OEM
Hi,
What is he using the PC for?
The balance doesn't look quite right to me.
That's an expensive mainboard for a cheap dual core when a Quad core Q6600 is only a little more.
Also is he looking for a gaming rig? if so then perhaps a single GTX for the main two screens and a cheaper 8600 or similar for two of the other monitors. depending on what type of game he's playing.... Flight Sim ?
Really depends on what he wants out of it and whether it's going to be overclocked.
AD
