Hi Guys,
on the brink of buying my new pc, can you check this spec and tell me if it's decent
or anything i should consider changing.
Samsung 160GB S300 7200RPM 8MB
Corsair Memory TWIN2X2048-6400 2x1GB 240-Pin DIMM XMS2-6400 CL5
XFX GeForce 7900GS 256MB DDR3 PCIE Dual DVI 450/1.32
Intel Core 2 Duo E6400 Socket 775 2.13GHz
Shuttle SB83G5M Socket 775 Intel 915G PCI-E ATX
BenQ 19" Benq FP91G+ 8ms TFT
LiteOn 16X DVD+/-RW/RAM DL IDE Black Bare Drive
This will set me back roughly about £850 so any suggestions would be welcomed
or anything i should consider changing.Samsung 160GB S300 7200RPM 8MB
